Ups about to fail?
Shadowarez
Arctic Canada
Recently I been getting a warning in win 10 that only pops up when I load a game or start encoding a project in Sony Vegas that's saying you're running on less then 5 mins of power plus unplug some devices.
Iv never had that in all the years this rigs been running. I installed the software for the ups have it plugged into a usb 2 port on back of computer.
Iv done weekly tests with it and it's passed everytime without a issue popping up. The only things plugged in is the computer itself.the router and my monitor.
Wondering if it's time to buy replacement batteries for this ups it's a 1500 watt ups cost about $350 when I bought it from ncix. It's got that pure sine wave 2 tech built in.
Shadowarez
Arctic Canada
Ok well it's served me well for nearly 6 years since my build. It deserves a clean start I'll look into batteries that are compatible and if they'd actually ship to Canada or least my part of Canada.
Valkyrie
Chilliwack...Time Is Just A Rubber Band....
Yeah, I think my first set lasted about six years also. The second set lasted about four years, but were a lower AH rating than the originals. The dimensions were the same, but I wasn't able to find the higher AH type locally. I'm currently trying to source the higher rated ones in my general area.
You should have no problem finding a Canadian supplier that will ship to you. Those AGM type Sealed Lead Acid batteries are pretty darn safe to deal with, as batteries go.
sswilson
Moncton NB
It's not finding somebody willing to ship, it's finding somebody willing to ship at a reasonable price. Getting replacement batteries shipped down to Atlantic Canada was crazy expensive except for options through Amazon.ca which had a flat rate shipping option.
Shadowarez
Arctic Canada
Yeah I'll have to get new batteries for this I'll do some searching on days off. I'll need to buy another one as well since I'll be setting up a HTPC. With my current build. Ty guys thought something was off when I seen the messages even in win 7. I'll get in finding replacement batteries shortly.
