usb problems
grizz
Member
Hi
Last few months I've starting having problems with what I thought a failing mouse.
I bought a new mouse was all fine for a week then booted up into windows and no mouse again, sometimes it boots ok sometimes not.
my specs are
asus rampage 2,
i7 920
6gb corsair ram
msi gtx770
ssd Samsung evo 850
1tb western digital caviar green
pioneer sata dvd drive
corsair hx850
Not sure what to check apart from what I've done cables, changing usb port etc , could this be a motherboard problem
nothing is overclocked
Thanks
moocow
Vancouver, BC
Disconnect all case USB cables, not remove the devices, I mean litterally disconnect the headers between the case USB and motherboard. If you still having issues, then I would try a reset the BIOS and then a USB card.
sswilson
Folding Team
Moncton NB
Do you have another PC to test the mouse (ice) on? Have you tried re-installing the chipset drivers?
KaptCrunch
Ontario
using keyboard to navigate
look in device manager for any ! yellow
other is Intel® 82801JB I/O Controller Driver
grizz
Member
Thanks for the replies, I will go through each 1 then test over the next few days
:thumb:
grizz
Member
Ok a little update
I tried all the fixes recommended earlier and my problems now seems to have gone
thanks to all that posted possible solutions :thumb:
