video card grinding noise?
kee23
New member
BC, Canada
hello,
i have a gtx 560 ti twin frozor 2 and for some reason, it started to make some very weird fan noise when I start my computer or wake it up from sleep mode, and then it returns back to normal fan noise for few minutes later.There's nothing wrong with performance, it just makes loud noise that it annoys me a lot every time I start the computer.
I found this out by touching one of the video card fans when it was making sound and the noise stopped.
I also cleaned the dust too and still made noise.
Does this mean that I need to replace my video card for a new one? Because it never happened before for 1st year use.
I need some suggestions.
KaptCrunch
Ontario
replace fan or lube it sounds bearings are worn out
peel back sticker on backside of fan to get at bearing
enaberif
Calgahree, AB
hello,
Those cards are notoroious for fan failures. Sounds like yours is happening too. Time for a RMA if you can.
mkultra
Canaduh
aftermarket fan, fan replacement, new card, either way don't wait for the fan to completely fail
