Video Card Water Block
WolfBane
new bruinswick
ok i need a water block what will fit this card ?
EVGA GeForce GTX 980 Ti CLASSIFIED GAMING REF ACX 2.0+
KaptCrunch
Ontario
real custom
that card is custom so non-reference best option is Hydro Series HG10 N980 GPU Liquid Cooling Bracket
note: copy the stock evga heatsink for the memory and regulators
or just take dremel to GPU area and add your own water block
KaptCrunch
Ontario
EK Water Blocks, Ljubljana based premium water cooling gear manufacturer, is pleased to announce that the existing*EK-FC780 GTX Classy*series water blocks*are compatible*with the latest EVGA® GeForce® GTX 980 Ti Classified graphics card.
seems EK saying its a screw-on but seeing is believing double check the ram and regulators are touching proper against your stock fan cover heatsink before using
otherwise will see this happen chips just melt off the card then DOA
WolfBane
new bruinswick
so my 780 water block should work as long as i make sure all chips are under water block ???
sorryr new to stripping a water block and installing onto another card :)
KaptCrunch
Ontario
BEST GET A HOLD OF vernier
to check clearances
WolfBane
new bruinswick
to check clearances
ok i have a venier but what tolerances am i checking ?
the gap between the caps ? if any etc etc ? or the lenth of the cooling area from the 780 to the 980 ti ?
sorry have never installed a water block on a vid card before ,let alone strip one and reinstall on another card?
is there any thermal pads needed or will tim be enough ?
KaptCrunch
Ontario
use playdoh as gauge
a dab on chip(s) then assemble heatsink
then remove heatsink and see the dabs if flatten or thick
get a mini screw driver set from Canadian tire
a egg carton and post notes the removed screws place in a egg hole and stick a note where it came from
