waiting for i9 9900ks
Smartinli
Member
Hi, I am wondering if there is any specific dates for the release of the i9 9900ks 9 on October? Also would there be any matching problems on motherboards I already have? How much w of power supply do I need?
Mr. Friendly
British Columbia
it will work on any Z390 mobo, but you likely need to flash to the latest BIOS revision for support. for PSU, a lot will depend on the rest of your system, particularly GPU and what it requires. I would say you'd probably want at least a 750w PSU though. I won't be surprised if this need 200 - 250w on full turbo, and if you have a 1080 Ti or 2080 Ti, that's another 300w+ right there.
Smartinli
Member
This is my setup, does is 1000w good or needs to be 1200w?
Also is is possible for the i9 9900ks to get sold out if I don’t buy it at the first time it’s out? Sorry i’m Just a little noob on computers3461D881-F71E-4BE1-9FCF-6570615AC5BC.png52596B69-EF71-4FA2-BA3A-B4DBF8C9339D.png
Entz
Kelowna
It might actually not be, I would wait to see what the 9900KS actually needs.
My guess is 400w just for the CPU alone, maybe more, if they are really going to hit 5GHZ all cores under full load.
Sagath
Folding Team
Edmonton, AB
There is no way. Most coolers are only designed for ~100w thermal dissipation, give or take.
Heck, even 240mm watercooling systems are usually in the neighbourhood of ~400w for CPU+GPU, according to EK.
Entz
Kelowna
A normal 9900k is in the neighbourhood of like 220w @5ghz with an all core of like 3.6. If this is at 5ghz all, its going to be insane..
Smartinli
Member
That does sound insane. Just wondering would it cost more than 600$ American dollar? Just asking for a prediction...
Entz
Kelowna
Actually that was about my guess. $549 USD +-, around 25% more than a stock
