Want to build budget gaming PC help
noob
Member
Planning to build a budget gaming pc that can live stream while playing fps game
  1. Msi b450 Tomahawk max atx or?
  2. GeForce RTX 2060 SUPER VENTUS XS J OC or gtx 1660ti?
  3. Amd ryzen7 3700x 3.6ghz 8core pro or ryzen 5?
  4. Thermaltake Versa H26 Mid-Tower PC Case
  5. Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory or?
  6. Samsung SSD 970 EVO M.2 Type2280 or?
  7. Please suggest what PSU should i use
Im planning to buy my pc parts on https://www.amazon.co.jp
What are some changes you will make/add?
Sagath
Folding Team
Edmonton, AB
Please review the sticky at the top of the new builds forum so we have a better idea of your key points (price usually) & what you're using the computer for.
We'll be able to give you a much better hand at building a PC this way. Thanks!
