Skippman
It occurred to me that I hadn't posted my latest rig after asking for parts recommendations. So I figured I post one.
Core Components
AMD Ryzen 7 3800X CPU
Gigabyte Aorus X570 Ultra Motherboard
G.Skill Trident Z Neo DDR4-3600 32GB (16GB x 2) RAM
eVGA GTX 1080 FTW GPU
Samsung 970 EVO+ NVMe M.2 SSD 500GB Boot Drive
Samsung 840 EVO 2.5" 1TB SSD Storage Drive
Creative Sound Blaster Z Sound Card
eVGA SuperNova G2 1000w PSU
Corsair Obsidian 700D Case
eVGA Power Link GPU Adapter
ASUS BW-16D1HT BluRay Burner w/ Libre Mode Firmware
Water Cooling
EK-Quantum Velocity D-RGB - AMD Nickel + Plexi Waterblock
EK-CoolStream SE 360 Radiator
Swiftech Laing D5 Pump
Monsoon Dual Bay Reservoir
Bitspower G1/4" Temperature Sensor
BitsPower 16mm PETG Hard Line Tubing
BitsPower Hard Line Fittings
Fan System
Corsair iCue Commander Pro Fan Contoller
2x LL140 RGB 140mm Dual Light Loop RGB LED PWM Fans
3x ML120 PRO RGB LED 120MM PWM Premium Magnetic Levitation Fans on the radiator.
Misc External Hardware
Acer Predator XB271HU 1440P/144hz IPS G-Sync Monitor
Logitech G-513 Carbon Keyboard
Logitech G-602 Mouse
Steel Series Arctis Wireless Pro Headphones
This is my first time working with hard line PETG tubing and there was a pretty big learning curve. When I build my next chassis I'm definately going to spring for some 90 deg fittings just to make everything easier on myself as some of the tubes had 3 or more 90 deg bends in them. I'll post pics later tonight.
Core Components
Water Cooling
Fan System
