Want to Buy Watercooling Parts
Yamcha
Calgary, AB
Watercooling Parts - Need 1/2" Tubing and Fittings + Dye
I'm looking for the following watercooling parts (Needs to work with AM2+) :
Water Block - Found
Radiator - Found
Water Pump - Found
1/2" Tubing
1/2" Fittings
4X 120MM Fans
PM me with your offers, Im located in Calgary, doesn't have to be local..
Yamcha
Calgary, AB
Looking for - 1/2" Tubings and Fittings, Tubing Plug.. Don't need ton of tubing, only cooling Cpu..
MpG
Kitchener, ON
For a tubing plug, just visit your local hardware store in the plumbing section. Shouldn't have any trouble locating a 1/2" brass plug. And even better, it'll probably be in the same aisle as the hose clamps.
Primu$
I have a couple feet of tygon 3/8" OD I know I have at least 5-10 ft left if interested pm me. this stuff is highy durable and very soft for easy installation on any setup fits over 1/2" fittings tightly (maybe tight enough you wont need hose clamps) YMMV. Let me know bro you just about cleaned me out! =P
1.50/ft + shipping Im guessing $10 bucks
Not used still rolled in a box, bought this a long time ago and been trimming for earlier project back in the days.
