Weird looking devices
trodas
Czech republic
I do have some weird looking non P&P devices in my Device Manager.
Anyone got a clue what the hell they are?
I also have there other suspicious drivers that does not support P&P, and their names are:
ATICDSDr
atidgllk
Beep - used, could this be removed for good somehow?
BOPOMAV
c34nb4c5
DirectX DLL register
e259q4c6
Fs_Rec
rvbedit (I killed this one already)
SSDefrag (I killed this one already)
NetGroup Packet Filter Driver
Parallel - used, could this be removed for good somehow?
YQZBNWOGRK (I killed this one already)
Can I remove/uninstall few of them?
Cptn Vortex
Vancouver
Uh.... I dont understand anything there....... It doesnt appear to be too english enough for me! hahaha
MpG
Kitchener, ON
Ditto. None of those are showing up for me either.
Those random letter/number combinations look mighty suspicious. Often, Googling them will bring up a surprising amount of information on them.
trodas
Czech republic
Well, fist at all, to see all these devices, you have to use the registry tweak:
Code:
REGEDIT4
;show all the devices in the hardware table
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment]
"DEVMGR_SHOW_NONPRESENT_DEVICES"=dword:00000001
And then reboot + choose in the menu again show all devices. Then you can see these.
And true, I had a mallware infection when I was running IE. Not anymore, but some stuff can remain there.
ATICDSDr - removed, no ill effects
atidgllk - removed, no ill effects (I do overclock, but I have nVidia card (ATI mobo chipset tough) and mobo I overclock in bios)
Beep - used, could this be removed for good somehow? Is not that the "beep" speaker anyway? We see if it come back :D
BOPOMAV - removed, no ill effects
c34nb4c5 - removed, no ill effects (probably related to PunkBuster)
e259q4c6 - removed, no ill effects (probably related to PunkBuster)
Fs_Rec - removed, but it keep comming back (should be File System recognizer)
NetGroup Packet Filter Driver - part of WinPcap - installed for Etheral sniffer, removed
Parallel - removed, but it keep comming back (parallel port disabled in bios)
YQZBNWOGRK - removed, no ill effects
