weird metal sound inside new RAD RX360
LegendMask
Montreal
one question though regarding flow meter, Im looking for something reasonable to watch my flow rate and be able to read it, Im looking at this bitspower flow meter, if any one had experience with it, and do I need two extra fittings for it? or can I just plug the tubes on each side and connect the reading cable to my fan control screen.
KaptCrunch
Ontario
seems their compression fitting just got to use correct nut to fit your tube
and yes it uses the fan header to see rpm not metered flow, to know if fluid is moving that's all
LegendMask
Montreal
Perfect, then no need for extra fittings. Im just gonna make a note of the RPM speed to keep an eye on the flow, incase something wrong happens and I start losing flow.
