Since I moved from the 9900x to the 9800x3d I've been noticing a couple "odd" things. Late last week I did a fresh install of Windows 11 to see if it would help with my COD DMZ crashes.
Since the Windows reinstall COD Blackops zombies gives me some artifacting ie the health meter will disappear or everything will disappear on the mini map or the whole screen will take on a brownish color and then the grass will slowly come back in blotches. Before the reinstall, Zombies was flawless.
COD DMZ, well... DMZ I've always had issues with crashes (directx) regardless of the build, guess can ignore this as it's just the default and isn't specific to this build (but if someone has any ideas, that'd be SWEET) Well, crashes do seem to be a little more, maybe once an hour. CPU and GPU temps appear fine. (CPU 55ish GPU 55-60ish)
Prior to the 9800x3d when playing world of war ships, I'd play the game and run plex flawlessly on the second monitor. Since changing from the 9900x to the 9800x3d Warships plays fine, but plex will consistently stutter. Even with the i7 it was perfectly fine. Both monitors are connected to the 4080, was thinking of running the 2nd monitor off of the integrated video. GPU though is at max 92% usage and 55-60C temp and CPU is under 50% and 50ish for temp.
Windows is fully patched, bios is up to date, did a bios reset last night, newest chipset driver from AMD. It's odd, I did a full uninstall and tried to install the chipset drivers from Asus. but it hangs on the determining specs page. Newest driver from Nvidia.
There is no overclocking (that I'm aware of) except for the ram, I did disable xmp to take that out of the equation, the system is set to "normal" in the bios and no overclocking on the GPU.
Any ideas or direction will be greatly appreciated
