Welll... this is certainly interesting..
matsta31
Montreal
:rtfm:
Speedstep C1E for Intel
it is the correct short answer.
For a longer one,
the multplier will go down if your system is idle and/or dont need the extra speed from the multiplier.
If you feel like it you can disable it in your bios, and keep your 9 multiplier.
refer to your mobo bios and look for speedstep settings.
Boldeagle
Brisbane, Australia
Keep CPU-z open and then give the CPU a nudge with Prime95 you will see it at 9x multi. What you are seeing is a power saving feature and to be expected.
Kayen
Edmonton
Oh all right, i suppose this is a good thing than.
Thanks for all your help!
