What are good speeds?
w0z
Active member
Halifax, NS
Hello,
I just setup a home server. Running WHS 2011. I was just wondering what good write speeds are?
I am running the Server on a cat6 directly connected to the router and i am transferring files from my laptop at about 8MB/s is this suitable or should i expected better. I am a nub at this stuff
Thanks
w0z
Coach
Morden MB
That depends if your laptop supports Gigabit LAN. My hunch is that it does not.
w0z
Active member
Halifax, NS
The server is connected to Linksys WRT-160N which is 100mbps not a gigabit. Could that be the reason why i am getting such slow transfer speeds. Is it worth it to upgrade the router to a gigabit or should i just get a gigabit switch and just use the router for wireless?
Keywork
Niagara
With fast ethernet, you can't acheive speeds higher than 12 MBps (100 Mbit). If you have some money, then a gigabit switch would be a welcome upgrade!
Edit: Also, keep in mind that your speeds may be limited by your storage, not your network (but at 8 MB/s I highly doubt it's your storage :haha:)
w0z
Active member
Halifax, NS
yeah it take me 6 mins to transfer a 2GB file... i was think i would get around 45mbps. I just not sure if i should buy a gigabit switch or router
and even which one to buy. Any suggestions
