What CPU is in a IBM per comp 730 - P75
ZZLEE
KANATA
what would the processor and memory be in this thing. Im wundering if it is worth saving. It has a good floppy and hard drive in it. and good CD drive also.
Thanks AL
I mean Is woth cost of a copy OF XP ?
_dangtx_
mtl
you might be able to load dos on it i guess. the p75 is 75mhz for cpu speed if im not mistaken. a collection piece, if it works, nonetheless
ZZLEE
KANATA
Cpu, Bord, Ram, Psu all look Origonal,
runs fine
Thanks
Not worth the price of XP on the maket now. thanks
liontaur
Member
Salmon Arm, BC
Here's What You Need to Use Windows XP Professional
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
I'd say it makes a great doorstop.
ZZLEE
KANATA
Its got sound card in it.
It has been playing music fore most of its life :)
Dos box good Idea
