What is everyone folding with?
lowfat
Grande Prairie, AB
Just curious what everyone is folding w/ these days?
For myself I have a watercooled GTX780Ti @ 1340 / 3875 which does from 275K to 295K depending on the WU.
Then I have a 2 x E5-2660 ES LGA2011 system that has been going hard since Christmas, however unfortunately it went down 2 days ago. :sad:
Shadowmeph
I was using my 2p AMD but it wasn't worth it, then I tried using SLIed 560tis but they got very very hot so I stopped until I can figure out something that will work that doesn't use allot of electricity and create massive heat
akira749
Donnacona, QC
I mostly fold on GPU's
I have currently 2 rigs running and the third one should be finished next weekend or so.
When all 3 rigs will be up and running I will have 2 x GTX 670 FTW, 2 GTX 770 and 3 GTX 780.
Currently the 670's give me around 74K~82K PPD each and the 770's give me around 94K~107K each.
On the 670's rig I have an i7 and I keep 2 cores for the GPU's so it fold on 6 cores....around 19K PPD
On the 770's rig I have an i5 and I keep 2 cores for the GPU's so it fold on 2 cores....basically nothing in PPD like 7K PPD
Since the 3rd rig has never fold I can't say how it will perform.
LoTech
Calgary
I to fold mainly on GPUs
1. i7 3930 GTX 780 oc and GTX 780 ti
2. i7 2700k GTX 770 and GTX 660ti
3. i7 3820 GTX 680 oc and GTX 670
4. i5 650 GTX 660ti.
Didn't really check into PPD etc as they seem to change all the time.
But for now those are the rigs that are burning coal to keep em running.
:thumb:
MARSTG
Montreal
Best PPD/$ seems to be AMD cards, I have a 280X clocked at 1150 is giving 140-150k PPD, you can see my stats on the EVGA team, I am getting my 10$ folding bucks and then I switch for the beavers.
SwingOP3
Regina
GTX980......
There appears to be room for more of them there megahertz's!:thumb:
Edit: Added 2 GTX 970's before Christmas.
SugarJ
Langley, BC
Holy cwap! What flag are you using to get those units? My core 21 units are around 120k PPD.
