What is this laptop part?
hfxmike
Halifax
A friend dropped his laptop pretty hard, and I'm picking up the pieces....quite literally.
It's an Asus K55N.
This was loose in the laptop and I'm not sure where it goes. It has dampening pads...
hfxmike
Halifax
left screen hinge socket damage - any advice...I've got nothing to screw into:
and the right side looks ok, but how do I screw this thing back together? The heads are flush:
help!
Bond007
Nova Scotia
Yeah or build up/fill in the holes with a glue and then use a more aggressive screw into it.
SpaceSquad
Ottawa
Best option is replace the bottom case.
Or like others have said some epoxy should do fine.
MacJunky
Grande Cache, AB
^^^^ What they said.
Epoxy up the bosses that have been broken and sheared off. Those round brass things hanging off the bottom of the hinge need to be in the bosses since the machine screws thread into them.
Make sure the epoxy is not mixed too brittle and prep your surfaces!
