what to check when buying a used video card
WantaPC
Active member
Hi guys
I am planning to buy a used video card from someone. We will meet at his place.
What should I do when I'm there in order to make sure the card works as described?
Thank you
justmehereajax
GTA, Ontario, Canada
I believe Passmark is a good benchmark. Numbers are available and consistent online.
A good game to test is GTA V. I think most people have that game in their Steam account.
Cannon Fodder
Mission, BC
Methinks you're making way too many assumptions:
1.) The OP didn't say what sort of card was being looked at,
2.) You're assuming the seller is a gamer,
3.) You're assuming that even if the seller IS a gamer, that he even has a Steam account, AND likes GTA type games.... oh, and btw, I don't have GTA V in my Steam account.
justmehereajax
Also because of all the fine details ... test all the fans spinning and noise levels. Replacing a fan can be somewhat costly. I hear OEM replacement fans can be found on Aliexpress.
sswilson
Moncton NB
Unfortunately, it's hard to recommend a used card to anybody these days unless they know the person they're buying it from. No way to tell if it's been mined on 24/7 for the last couple of years and is a candidate for a fan failure.
danmitch1
Buyer beware eh... Its always a gamble, even if the card was the best taken care of card in the world who's to say the moment you install it that it wont fail. Question should be, do you feel lucky punk? ..lol
gingerbee
Orillia, Ontario
it's always a gamble but if you're going to the seller home I would run heaven benchmark for 10 to 20 mins and max out the cards heat/power/fans you can download it for free or bring it on a flash drive my2cents
