Whats up with my CPU? - A SpeedStep F.A.Q.
thenewguy001
Vancouver
obligatory lolcat picture
matsta31
Montreal
Wow great job.
even if the next ''new to overclocking poster'' does not read it, we can just make answer with a link !!!
If we were on NCIX I would tip and rate your post !
WolfBane
new bruinswick
Ok so i read your post:)
very informative ! If i understood it lol speed step powers down my chip when nnot needed ???
But is this a really good thing?
Should i disable speedstep or leave it alone?
and if i do disable it , How do i disable it ?
Chilly
Ontario
I suggest you re-read the post again, I answer the "should you disable it or leave it on" in the "leave it on or off" section :haha:. But yes your correct, all SpeedStep does is power down your chip when its not needed/not in use. Once you re-read the part about leaving it on or off, and if you decide to turn it off, there are 2 ways to disable SpeedStep. The easiest way is through software.
Seeing that your using Vista, here is how you do it; Post above updated, read above post for how to "disable" speedstep in Vista.
I'll work on and finish the "How to disable" sections later today. I really should get around to finishing this thread. :haha:
somecanadianguy
somecanadiancity
:thumb:
Good info!
A couple things I've noticed...
Voltages don't appear to change unless they're set to 'auto' in BIOS.
I have EIST and C1E enabled and don't see any voltages drop when bclk and multi drop.
Also, with EIST and C1E enabled in BIOS and "high performance" power setting in Vista, idle wattage still appears to drop even though nothing else does.
Am I doing something wrong?
Is this safe?
Chilly
Ontario
Working on updating posts, will be adding some information how turbo is affected/works as a part of SpeedStep in the other notes section.
Is this safe?
You are doing nothing wrong, voltage drop during idle periods while the multiplier is dropped is a feature of SpeedStep, but one I've never seen implemented outside of laptops.
As for why your seeing the wattage drops, despite no voltage change, this is because EIST and C1E and change the state inside your CPU, effectively turning off unused parts to save power. There is nothing wrong, and it is entirely safe.
