What's up with one of my GPUs?
redwagon
Calgary, AB
One of my gpu's is only pulling in 2800ppd. Is there something wrong with it?
The good news is the other one is running at 6500ppd.
chrisk
Folding Captain
GTA, Ontario
I see you folding on a cpu. Stop that one for a bit and see what happens.
What cpu client are you using?
Zero82z
Montreal, QC
Under Configure>advanced tab make sure the slider is all the way to the right. It says CPU but it means GPU.
Actually, it does mean CPU. That slider controls the amount of CPU time the client will allot to the core, since even GPU folding requires CPU time in order to operate. It should still be set to 100% since otherwise the client might end up starved for resources.
