Which 120mm fan for Ultra 120 extreme
Jacka
Active member
Vancouver
Anyone know which fan is best for Ultra 120 heatsink? I have a fan controller so i can adjust speed on fan too.
Sushi Warrior
Grimsby, Ontario
What do you mean by "best"? "Best" would be like a 3-4k RPM delta or san ace. Best noise/airflow is either Scythe SFLEX or Noiseblocker fans.
Zero82z
Montreal, QC
Scythe S-Flex or Gentle Typhoon would be my choice. S-Flex for maximum performance, GT for best noise/airflow ratio.
Silvgearx
Toronto
Scythe S-Flex are good high static pressure fans and they do a good choice for its price.
But when those S-Flex are undervolt they tend to make clicking noises.
just go for the S-Flex 1600RPM one. rated at 63CFM and 28DBA, that should be good enough for average overclockers
crazyhorsejohnny
Ottawa
I haven't come across that. But yeah the 1600rpm one is plenty.
CanadaRox
Scarborough (Toronto)
I've never had any problems undervolting. I used two 1600RPM ones in my HTPC, one at 7V constant and the other variable depending on CPU speed and they both sounded amazing.
Boldeagle
Brisbane, Australia
