Which firewall to get ?
JD
Toronto, ON
If you're going to use TLS then you need this line as well I believe:
Code:
ns-cert-type server
And make sure you followed this to generate the certificates correctly: HOWTO
Angela Byron
New member
If you are using a work computer on a corporate network then will be great Cisco PIX, otherwise Alpha Shield is also a good choice.
