Wierd Crash Error
X9999
Member
2 Days ago I started getting a blue screen about every half hour with uncorrectable hardware error running on Windows 7 build 7100.
Error
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA8004A98028
BCP3: 00000000F2000040
BCP4: 0000000000000800
I ended up testing my memory with memtest and the one with windows and found no errors. I then put my cpu back to stock 2.4 GHz with stock voltage 1.2875 volts and the same blue screen happened within minutes multiple times. So I tried 2.4 GHz with 1.3 volts didn't blue screen right away but did within about 20 minutes twice. I found with high vcore blue screen came slower. I tried 1.4 volts in bios next at 3.0 GHz for the heck of it and only took 2 hours to blue screen, so now I'm at 1.425 in the bios and it hasn't blue screen yet about 34 hours @ 3.5GHz. I haven't tried reinstalling but seams stable with a higher vcore. The computer was idle the times it crashed. Hardware specs in sig.
X9999
Member
thanks for the tip. I found the main ATX connector wasn't fully square so the top part was little loose and I was able to get it to boot finally at stock has been running so far fine for 4 hours at 2.4 GHz with 1.2875 volts, I hope that was the problem.
