Will this cooler work on DDR3?
_dangtx_
mtl
overall dimensions should be similar, now depending on the heatsinks as well.
because of the flexible clips i wouldnt worry.
now, wouldnt a 120 strategically placed above do a better jobbe than those 2 4500±10% RPM puny ones? :)
Slaughter
Age
34
Toronto, ON
I think aesthetics are a bigger factor in this case as opposed to performance...
Again, as dangtx mentioned, it will depend on your factory heatsinks (if your memory has them at all). Otherwise they should be fine! At ~$15 you aren't going to take a big loss.
