Will tri-chanel ram sticks work in a dewl-chanel configeration?
Newfoundland
Well like the topic sugests I am wondering if a tri-chanel ram stick's work in dewl chanell confirgation? That is can I buy a tri-chanel kit and only use 2X of the sticks on my LGA775 board?
Thanks
Flasker
Yes you can use 2 sticks for dual channel, be sure to keep the voltage within warranty limits.
These kits were designed for x58, so you may not get rated specs on a 775 mobo.
sswilson
Moncton NB
Ok folks. Spelling or gramatical critiques of members' posts are not helpful unless there is a legitmate comprehension issue.
HWC membership has a pretty good rep as a friendly community, I'd rather not see us lose that reputation for the sake of a few misspelled words.
DaleF
Burnaby, BC
I'm pretty sure if I was running dual channel, I could run my memory at 1333MHz, but in triple, only 1066MHz.
