Win7 32 bit - ram upgrade to 3GB or 4?
hfxmike
Halifax
I'm trying to get whatever I can out of an aging computer with 2 GB of ram currently installed - with Win 7 32bit. If I upgrade to to 4GB, only 3.5 or so will be useable, but what if I upgrade to 3GB? Will I be able to use all of that? Or 3GB minus whatever the video takes? (I think the video uses 256 megs).
I don't want to upgrade to 3GB only to see 2.5 available.
hmm
JD
Toronto, ON
You should be able to use the full 3GB.
That being said though, if you currently have a single stick of 2GB in there, you should buy another stick of 2GB so that you keep dual-channel capability and thus slightly faster memory performance.
Really though, Windows 7 should run fine on 2GB as well, depending what your doing.
