Windows 7 Installation Problems: Stuck at Expanding Windows Fles
flightsimnerd
Mom just brought home my new WD 640gb Caviar black so i went to install w7 on it but it gets stuck at Expanding Wndows Files :(. I have tried new sata cables, different sata plug on the mobo and all give me the same resultAny ideas? Please help!! I am installing with my dvd drive btw
clone63
Bellehole
If that doesn't work, try using the same HDD on a different computer (for sake of trying a dif. mobo)
Chromey
Acton, Ont
HAd the same issues with 64 bit.
After 20 or so trys it worked... Then crashed every 10 mins after...
Windows 7 = Epic Fail for me.
b1lk1
Lindsay, Ontario
So far I have only had good luck with Windows 7 on my laptop and since it came factory preloaded with it that is what I believe has made the difference.
Eldonko
Calgary, AB
Sounds like the disk is shot. I keep my W7 on a usb stick to avoid such issues. Glad u got it working
