Wireless adapter
JD
Toronto, ON
Anything that works with Vista will work in Windows 7 as far as I know.
Basically anything will do, though if you have a 802.11n router/network, I'd suggest buying the company suggested one to obtain the best speeds.
rapmaster
Brossard, QC
I only have a 802.11g router so I will be buying a wireless g adapter since it's cheaper. Any suggestion for a reliable one?
JD
Toronto, ON
No idea really since I don't use wireless on any desktops.
I'd say stick with D-Link and Linksys though.
