Wireless adapter
Matthecat
KaptCrunch
Ontario
for the wireless connection is best when seen each other (line of sight)
not through wall's or floor's
best go with a wired connection IMHO. your MB don't have WiFi onbpard would need a wireless NIC
Qusetion! you own the home ?
Matthecat
No lol. I'm 15 and I live with my parents. There is a possibility that I can move the router into my room, we'll see.
JD
Toronto, ON
Are you or your parents handy? Running cables isn't typically too hard to do...
If you have to go wireless though, I'd make sure you have a solid wireless router firstly so that the signal your broadcasting is at least decent and reaches up to your room.
The card you put in your computer doesn't matter too much really.
_dangtx_
mtl
both ends matter, a lot.
i would still drill a hole tru a wall or two before going wireless.
better security,no drops/screwing around signal wise :)
Matthecat
yeah I'll just nag my dad to get a wired connection lol. Saves me money too because we have cables a plenty. heh
supaflyx3
Langley, BC
plug 1 adapter in your wall by the router, and plug the second one in your room where ever you want ethernet, it runs through your electrical circuit.
