wires touching mobo? is this ok? thanks!
go flames go
thats how i routed the cable for my 9900led cooler. is it ok if the wire touches the capacitors and slightly touches one of the pipes on the cooler? I dont want any mutation/melting of wires:ph34r:
M
member 3099
Guest
Should be alright.. my fan wires are routed in a similar fashion... no problems here.
go flames go
ok good cause i wedge er in there and if i had to take it out id have to remove the cooler probably ;)
MpG
Kitchener, ON
As long as the wire isn't actually being pinched, it'll be fine. If it is, it's likely shifting the pressure of the CPU cooler, and there's always a chance that, over time, you could break through the insulation.
