Wiring SPST LED pushbutton 6-pins
kalinka
New member
Hi,
I recently bought this push button from ebay.
I would like to wire it between a 12V powersupply and a 12V 2-pin fan as I have attached to my WRT54GL router.
I am quite confused on how to do this properly. I have only experience with wiring 3-pin Rocker Switches.
Thanks in advanced :)
KaptCrunch
Ontario
need to know if led light is 3.3v or 5v for to use correct resistor, if not use one will burn out led, possible melt switch
other is what your total load for switch......watts or amps don't exceed switch rating 50mA, if need to use a relay
strange diagram states SPST
