Wolfking Warrior
I own this one. I kind of like it. The tab and shift keys are small and hard to find but the plethora of buttons convenient for the thumb kind of makes up for that. The two games I have been playing with it do not have the shift to run control style. Ergonomically it allows my hands to be closer together and my elbows to be in a better position. It is just a gimmicky toy. It will not take you up a notch or anything. For a few bucks it was fun to play with but then I like to play with different key input strategies.
Wow, the first time you use that keyboard, you must be really confused... but look really conformy. I'll stick to my good old Saitek keyboard :P
why not customize the keys, every game has it :whistle:
I use this Wolfking keyboard
bit-tech.net | Review - Wolf King Timberwolf Gaming Keyboard
And it easily the best gaming keyboard I've ever used, and likely will continue to use it till it dies. It took a long time to get use to it, and you will need to change your quicksave from the F4-F5 key to something located on the left game pad. After using it for a few months, I will never go back to a normal keyboard for gaming. I don't use it for typing, but everytime I game I plug it in.
:dots:That is just plain stupid. Cmon, it s a marketing gimmick LoL and a decent one. See it, for what it is.
You can't really judge it till you try it. Like I said, I wouldn't even consider using any other keyboard out there when it comes to gaming.
I use a
Ideazon™ Precision Gaming Tools [Merc Gaming Keyboard]
These keyboards aren't marketing they are designed to be used for gaming, its a lot more comfortable and keys are strategically placed.
Also, Ive seen that avatar before, seen ya on XS lowfat,
I would use that keyboard if it were the only keyboard I had hooked up as it has a number pad. The Wolf King Timberwolf doesn't have one. I've never actually tried the Merc but I don't have any problems with my Timberwolf.
