Worth swapping in more efficient PSU?
sswilson
Moncton NB
I've got a system running 24/7 that's drawing under 200W. It's currently running on a Corsair CV650 650W 80+ Bronze PSU, but I grabbed one of the 550W Seasonic SSR-550FM 80+ Gold PSUs from the recent sale as a household spare.
Would it be worthwhile swapping the 550W one in? Not only is it a higher efficiency PSU, I suspect a 200W draw would be more in line with the max efficiency of a 550W PSU than it would be of a 650W.
Thoughts?
gingerbee
Orillia, Ontario
it all depends on the efficiency rating of those PSU at the power draw you using. you know its different for every PSU I don't know what those units power efficiency curve is like, I myself have always gone with Seasonic but that's just to my liking
Izerous
Folding Team
Edmonton
Make a copy and fill in more accurately if necessary but the difference in efficiency from going from like 30% load to 33% load is pretty much irrelivant i think.
I randomly entered $0.07/kWh i don't recall what the current rates are
JD
Toronto, ON
Seems silly to leave a Gold PSU on the shelf and keep running a Bronze. Plus with age, I'd imagine a PSU becomes less efficient?
And wow, power is that cheap in Alberta? Our off-peak is 8.2c in Toronto and doubled to 17c at peak.
Bond007
Nova Scotia
I wouldn’t say it’s worth buying a higher tier psu to swap in, but if you already have it, then absolutely! Sell the old one.
sswilson
Moncton NB
We don't have tiered KW/h in NB so it's a flat 11.38c.
I'll punch in the numbers tomorrow, but yeah I'm inclined to swap it out since I have both on hand.
Izerous
Folding Team
Edmonton
No tiered power and the last couple bills have been higher but i'm pretty sure during the summer I was looking at 7-8c/kWh I think we are closer to 12c right now but my wife handles the monthly bills so we can note it for the rental etc.
Valkyrie
Chilliwack...Time Is Just A Rubber Band....
Probably a little over a couple of bucks a month for 200 Watts 24/7 difference between 90% and 80% efficient PSU's based on $0.11 KWh. Efficiency is highest in the midrange and lowest at the bottom end as I'm sure you know.
sswilson
Moncton NB
Heh... $2 is $2....... :)
And yeah, because of the relatively low power draw, I was already leaning towards the efficiency curve possibly being a bigger deal than the gold vs bronze rating. Now that I've had a second look at the PC's config, I'm realising that it's probably closer to 130/140W than 200 so maybe I should source a 400W PSU. :)
Either way, I did the swap this morning and everything is back up and running.
Valkyrie
Don't blow your savings on another PSU...unless you really want to..:)
