X99 help in Lower Mainland
SugarJ
Langley, BC
Hey all,
My main system has started not to POST. I'm hoping to find someone in the Vancouver area that might have some parts that can help me troubleshoot. I'm running a 5930K, MSI X99A SLI Krait and 4x4GB Corsair Vengeance LP DDR4-2400 or was until it pooched :angry2:.
Here's what I've tried so far.
Disconnected all drives and pulled all ram except one stick. Rotated ram sticks too.
CMOS reset
Battery replacement and CMOS reset
Moved to another PCI-E slot with GPU. (GPU tested good on another system)
Replaced PSU with known good PSU.
Changed to backup BIOS, battery pull and CMOS reset.
What I'd like to do is try my CPU and/or RAM in a working system. I think this is probably motherboard related so if I can confirm the CPU is good I'll RMA the mobo.
So I'm looking for help and/or suggestions. Thanks!
EDIT: I should mention I also tried a different monitor with no luck.
KaptCrunch
Ontario
MSI X99A SLI Krait what was the bios version current is N5
check cpu socket for bent pin or bad cmos chip(MB)
Only the FAT32/ NTFS format USB flash disk supports updating BIOS by M-FLASH, use rear usb2 ports
BIOS recovery with AFUDOS command When BIOS updating fails or causes the computer non-bootable, you can recover the failed BIOS by the steps below.
Preparation:
1. Prepare a bootable USB flash drive.
2. Download the latest BIOS file from the MSI official website at www.msi.com, and then decompress the file.
3. Copy the AFUDE238.exe and the BIOS file to the bootable USB flash drive
BIOS recovery steps:
1. Power off the system.
2. Set the Multi-BIOS switch to the functional BIOS ROM.
3. Insert the bootable USB flash drive you have made to the USB port.
4. Boot the computer into the bootable USB flash drive.
5. Set the Multi-BIOS switch to the failed BIOS ROM.
6. Execute the below command to flash the BIOS: For example: AFUDE238 EXXXXIMS.XXX
7. Restart the computer after the BIOS flashing is complete.
Important Do not use the Multi-BIOS switch when system is booting up.
AFUDE238.exe Usage: AFUDOS <ROM File Name> [Option 1] [Option 2]...
or
AFUDOS <Input or Output File Name> <Command>
or
AFUDOS <Command>
Commands:
/O - Save current BIOS into file
/U - Display ROM file's ROMID
/S - Refer to Options: /S
/D - Verification test of given ROM File without flashing BIOS.
/A - Refer to Options: /A
/CLNEVNLOG - Refer to Options: /CLNEVNLOG
Options:
/P - Program main BIOS image
/B - Program Boot Block
/N - Program NVRAM
/E - Program Embedded Controller Block
/K - Program all non-critical blocks and ROM Holes
/Kn - Program n'th non-critical block or ROM Hole only(n=0-7)
/Q - Silent execution
/REBOOT - Reboot after programming
/X - Don't Check ROM ID
/S - Display current system's ROMID
/R - Preserve ALL SMBIOS structure during NVRAM programming
/Rn - Preserve SMBIOS type N during programming(n=0-255)
/ECUF - Update EC BIOS when newer version is detected.
/SHUTDOWN - Shutdown after programming.
/HOLE: - Update specific ROM Hole according to RomHole GUID. NewRomHole1.BIN /HOLE:RomH1
/HOLEOUT: - Save specific ROM Hole according to given GUID. NewRomHole1.BIN /HOLEOUT:RomH1
/SP - Preserve Setup setting.
/EC - Program Embedded Controller Block. (Flash Type)
/MEUF - Program ME Ignition Firmware Block.
/ME - Program ME Entire Firmware Block.
/CAF - Compare ROM file's data with Systems is different or not, if not then cancel related update.
/A - Oem Activation file. Example: /Akey.bin will update OA key with key.bin file.
/CLNEVNLOG - Clear Event Log
Coach
Morden MB
RMA motherboard. That is what I would do. Isn't there an MSI RMA depot somewhere in Vancouver? Maybe you can initiate an RMA and then go over there to make the exchange. Very unlikely that it is the cpu and your troubleshooting has been thorough.
SugarJ
Langley, BC
RMA started. Knuckles savaged trying to dismount mobo without removing WC loop. Feeling faint from blood loss. :bleh:
SugarJ
Langley, BC
RMA'd motherboard received back, exact same issues. Sigh. Now I have to figure out how to RMA my Retail Edge 5930K. I'm not looking forward to this.
turtletrax
Edmonton(ish)
5930k was my first cpu rma. I have had dozens and dozens of chips and I used to beat on them like they owed me money. Kind of interesting to see them become less bulletproof as they shrink and become so complex.
The Rma process was surprisingly easy, but wasn't an RE chip... Hope you get it sorted.
On the up side, if you do get it rma'd, they are usually awesome chips.
SugarJ
Langley, BC
I looked it up last night, it's actually pretty easy to do seeing as I still have my invoice. But I have to take the CPU out of the board first, they want some info printed on the heatsink.
SugarJ
Langley, BC
It appears that one of the voltage regulators blew on the motherboard, taking the CPU and memory out too when it went. I was able to get the mobo and cpu RMA'd, and have since moved away from the X99 platform.
D
Dark Knight
Guest
That sounds like what happened to the ASUS X99 Deluxe to reviewers in 2014.
