XFX 780i Not detecting XFX GTS 250
Moatsim
Member
Guyz suject says it all.
I was previously using 9800GTX+ on my mobo. yesterday i bought used gts 250 but the dam gpu is not working on my mobo. when i install it doenst give display and beeps like it dont have any gpu installed on it.
MSI 9800gtx+ was working very fine on my mobo and it still does, but gts 250 desn, the same card is working fine on my friend's mobo though.
what is this all about please some 1 help..
martin_metal_88
Quebec City
First of all, welcome to HWC! I hope you will enjoy the place.
Now serious business.
Try to clear Cmos. Some board are sissy about hardware change.
After that if it still dosen't work, can you give us your complete system config?
_dangtx_
mtl
its more or less the same gpu, so it should work. does it work fine in another pc?
edit. ok so if it works in your frends pc then its weird.
sswilson
Moncton NB
He's using an xfx 780i.
Heh... thanks.... I knew he had it listed up there somewhere, but I didn't see it in the text of the message.... :)
Have you tried the different slots? What power supply are you using?
edit: This is going to sound strange, but are you absolutely certain the card is seating properly? Reason I ask is that I've got an XFX 280GTX that absolutely will not seat properly on one of my external cases, while all other cards work fine. I ended up having to fold the card mounting lip back. Check the backplate to see if there is any room to loosen it up and move it up a bit.
Coach
Morden MB
As mentioned earlier the first thing would be to make sure that the card works by trying it in a different pc, ie. your friends. Is that what you meant when you said
Moatsim
Member
System Specs:
XFX 780i Sli
PSU: CM slient Pro 600 Watts
CPU : E6500
3GB Kingston DDR2 800MHZ
and yes i did connected 6 pin power cable to GPU. its sitting fine in slot. Besides, could there be any issue with Mobo bios??? are these need to be updated if yes then how.
Pleas help :(
Moatsim
Member
Yes my friend has an AMD mother board. it worked fine on that against my very own eyes
