XMP PROBLEM
GeorgeM
New member
Hi,
quest for nut material stops here, my dude. this adults-only playground streams nonstop live sex from every time zone. early sunrise? thai chick bouncing on dong. lunch hour? euro cam-whore stuffs entire bedpost. bedtime? american milf twins 69 each other while hundreds jerk in xxx chat. tipping gets you moaned names, but private adult cams unlock the nasty - anal fisting, piss play, dp machines. site even saves your fav webcam models so you can rejoin their room one handed without searching. bookmarks for your boner, genius.
heyyoo, lock the door cos these sex cams are filthier than a gas-station toilet. every kink gets served: skinny thot spin a dildo on mirror, cosplay elf buttfucks herself with arrow, muscle couple lift-n-fuck position you can't even pronounce. free live sex means you lurk shame-free, but dropping 50 tokens gets a model pounding her ass so loud your neighbors hear. xxx chat window scrolls requests like "make cream pie" and she instantly pushes cum back inside for round two. earth's rotation slows while you beat meat; who needs netflix?
I haven't messed with ddr5, so I don't know the voltages off the top of my head, but you may have to go up on memory voltage it may not set it right in the bios which I doubt but sometimes it just needs more voltage, I would look up the ram you have and see what is the safe daily use max voltage and see what the bios settings are at.
it seems the tested voltage corsair uses is 1.4V
I've had success with XMP and DOCP profiles, but pushing RAM is often never as simple as just set it and go if you are trying to push the RAM to its limits, as @gingerbee said. There are impacts of changing voltages and settings, and that often takes a lot of iterations to find the stable happy place.
When you said you set XMP 1 and try to go up to 6400 MHz, do you mean that 6400 MHz is the speed you get when you set to the XMP 1 profile, or are you setting to XMP 1 and then trying to go higher manually?
Remember that setting XMP profiles changes more than just your RAM settings too, so you could be getting into a settings combo trying to reach 6400 MHz that your CPU doesn't like. Others more experienced in overclocking can correct me if I'm wrong there but I believe that's the case.
hmm I just built a new system am5 7600 and having issues I am wondering if its the ram currently doign the win11 ram diag my ram speed is supposed to be 6000 for some reason auto is detecting it at 4800 so I manually set it to 6000 left everything else on auto but when rebooted intop ram dia it immediately said hardware problems detected which I have know clue what that is have to wait but this post made me rememebr something from probably a decade ago when I posted on her someone suggested to check the voltages which in that case fixed my issue once I manually set it . another part of me is thinking that it possibly could be my msi board and the gskill ram not likely each other
if you just changed the speed and not the rest of the settings/voltage, that is why it won't run (you will likely never get 6000mhz out of any ram at jedec voltage). 4800 is the jedec speed. Either manually set everything, or just load the xmp/expo profile to get to the rated speeds.
