XP - Lan but no internet - Need PRO help.
MittWaffle
XP - Lan but no internet - SOLVED
Solved! Thanks!
Hey guys I need a huge favour.
I recently used my friends HP recovery cd to help him out however everything is well except this.
Internet is set on LAN - 100MBPS and no internet connection is possible.
I've used repair but get the an error related to no ip address.
I've used the ipconfig /renew /release and i get no DHCP server.
Used it directly to the modem...nothing.
So i've come to realize is related to XP and not any external factors.
This is XP sp1 on a HP Pavillion a1420n.
I have my network drivers setup, and im stuck everything on google has lead me to a dead end.
If anyone can help me i'd REALLY appreciate it as i have no solution currently.
***Update***
Network card has newest drivers installed and its working perfectly, other drivers (vga etc still need to be installed)
IPConfig is giving me a ip addess and subnet mask
it isnt giving me a DNS Suffix or default gateway.
The ip address is 169.254.xxx
Were getting somewhere but what would be my options from here, directly connect to the modem and ipconfig /renew and /release ?
***Update***
Did the direct modem, CMD, IPCONFIG /RENEW = "Unable to conect to DHCP Server - Request timed out."
Must mean XP is at fault? Everything points to a config fix or setting fix that is needed to allow a connection in.
Still looking for a solution.
***Update***
***Update***
The solution?
To use a add in card for Ethernet, plug and play. No issues, finally!
3.0charlie
Bedford QC
Shutdown rig, Router (if any) and modem.
Restart in the following order: modem - router - rig.
Before starting the router, make sure the modem is fully started.
Before starting the rig, make sure the router is fully started.
MittWaffle
I have done this, still nothing. I will get a screen shot of everything for you guys. Give me a minute.
sswilson
Moncton NB
A 169 IP address is an internal address that can often be difficult if not downright impossible to get rid of.
Best bet is to delete the network card from device manager which will basically cause windows to rebuild the TCP/IP stack when it re-discovers the card and installs the drivers.
MittWaffle
I cant seem to get rid of it, i've uninstalled it from the device manager but when I attempt to restart it auto installs then i update the driver.
It looked good at first, saw 0.0.0.0 in the ip address..soon after the 169 ip address appears again.
Pike
Collingwood, Ontario
Correct me if I'm wrong but that's an integrated nic and I had the same one on a gigabyte board and had the same problem. For me, I just installed one of many cards I had laying around and fixed the problem. But I never could figure out the issue. Would be interesting to see if this gets resolved.
MittWaffle
Hey guys
I didnt think I had a network card but I found one from a old P1.
Guess what?
It works perfectly now, no issues at all im actually typing this on it right now.
Thanks for the help everyone my problem is solved!
Pike
Hey guys
Guess what?
Just out of curiosity...what brand and model of nic did you use?
