AMD Ryzen 5 1600X & 1500X Performance Review
Editor-in-Chief
AIDA64 Extreme Edition
AIDA64 uses a suite of benchmarks to determine general performance and has quickly become one of the de facto standards among end users for component comparisons. While it may include a great many tests, we used it for general CPU testing (CPU ZLib / CPU Hash) and floating point benchmarks (FPU VP8 / FPU SinJulia).
CPU PhotoWorxx Benchmark
This benchmark performs different common tasks used during digital photo processing. It performs a number of modification tasks on a very large RGB image:
This benchmark stresses the SIMD integer arithmetic execution units of the CPU and also the memory subsystem. CPU PhotoWorxx test uses the appropriate x87, MMX, MMX+, 3DNow!, 3DNow!+, SSE, SSE2, SSSE3, SSE4.1, SSE4A, AVX, AVX2, and XOP instruction set extension and it is NUMA, HyperThreading, multi-processor (SMP) and multi-core (CMP) aware.
CPU ZLib Benchmark
This integer benchmark measures combined CPU and memory subsystem performance through the public ZLib compression library. CPU ZLib test uses only the basic x86 instructions but is nonetheless a good indicator of general system performance.
CPU AES Benchmark
This benchmark measures CPU performance using AES (Advanced Encryption Standard) data encryption. In cryptography AES is a symmetric-key encryption standard. AES is used in several compression tools today, like 7z, RAR, WinZip, and also in disk encryption solutions like BitLocker, FileVault (Mac OS X), TrueCrypt. CPU AES test uses the appropriate x86, MMX and SSE4.1 instructions, and it’s hardware accelerated on Intel AES-NI instruction set extension capable processors. The test is HyperThreading, multi-processor (SMP) and multi-core (CMP) aware.
CPU Hash Benchmark
This benchmark measures CPU performance using the SHA1 hashing algorithm defined in the Federal Information Processing Standards Publication 180-3. The code behind this benchmark method is written in Assembly. More importantly, it uses MMX, MMX+/SSE, SSE2, SSSE3, AVX instruction sets, allowing for increased performance on supporting processors.
FPU VP8 / SinJulia Benchmarks
AIDA’s FPU VP8 benchmark measures video compression performance using the Google VP8 (WebM) video codec Version 0.9.5 and stresses the floating point unit. The test encodes 1280×720 resolution video frames in 1-pass mode at a bitrate of 8192 kbps with best quality settings. The content of the frames are then generated by the FPU Julia fractal module. The code behind this benchmark method utilizes MMX, SSE2 or SSSE3 instruction set extensions.
Meanwhile, SinJulia measures the extended precision (also known as 80-bit) floating-point performance through the computation of a single frame of a modified “Julia” fractal. The code behind this benchmark method is written in Assembly, and utilizes trigonometric and exponential x87 instructions.
The first couple of benchmarks prove that Ryzen 5 aligns exactly where AMD intended it to. The 1600X’s 12 threads allow it to effectively remain ahead of Intel’s 7700K except in situations where Intel’s higher clock speeds win out like in Photoworxx. The same can be said about the 1500X versus 7600K and 7500. It is hard not to be impressive by what AMD has brought to the price / performance table, particularly in AES encryption / decryption.
Latest Reviews
