Valve announces three new products: here's what you need to know
Good things come in threes?
*with FSR it said...I'm guessing 1080p render resolution, upscaled to 4K.I would think you would want more for their 4k 60fps claims.
8GB vram seems like a mistake. I would think you would want more for their 4k 60fps claims.
Ehhh, I think 8GB VRAM is probably fine, this think isn't billed a a PS5 Pro killer, unless they really miss their price point. Keep it close enough to console pricing, likely a touch higher, with it being billed as a fully useable PC with Steam and Steam BP integration as the driving factor over a Windows PC.This is very likely the case and is the same way the other major consoles work as well. There's also likely going to be a native streaming option built in to it for high quality, low latency streaming from your gaming PC.
I believe it's already confirmed as 6e.Wonder if it'll have WiFi 7 by time it releases I can finally use it on my network.
Do the consoles even have dedicated VRAM? I thought it was a shared pool of 16GB. My main concern would be the lack of compute units though, I don't think more VRAM would help anyhow when it's only got 28 CUs.I think 8GB VRAM is probably fine, this think isn't billed a a PS5 Pro killer,
Shared on the modern consoles as far as I know. Not sure if the Xbox Orignal or PS3 had dedicated ram too since they were kind of weird machines.Do the consoles even have dedicated VRAM? I thought it was a shared pool of 16GB. My main concern would be the lack of compute units though, I don't think more VRAM would help anyhow when it's only got 28 CUs.
Valve might be able to work some software magic, like consoles do today. On the handhelds, people have seen that some games do run better on Linux compared to Windows even with the Proton layer.
However, I also see this as being Valve showing OEM's what to do, and then somebody like say Lenovo will come along with a more potent version (again, drawing comparisons to Steam Deck and Legion Go). Fundamentally this is just another mini-PC using laptop components without a display.
