its Not booting
fightingfi
I have this https://www.gigabyte.com/Motherboard/X870-GAMING-WIFI6-rev-1x. Im having issues with windows 11 and want to go back to 10 with esu its fine its on my other pc no issues.......The problem is it wont boot from usb from the windows media creation setup, save in bios change boot order etc...csm on , csm off tried every single usb port on the case and back of the motherboard, 2 different perfectly fine usb drives 32 gig formatted everything........called Gigabyte the guy told me you cant boot from usb to install on this motherboard.........Well i did before with NO issues between windows 10 and 11 off and on........Any ideas?
You might need to disable secureboot.
oh man now im missing a driver some kind of pci device, ive got the new amd motherboard chipset drivers installed, new amd video car ddrivers nic audio etc........usb installed any program i can use to locate what it is? MS updates found nothing
You can lookup devices using their respective Hardware Ids.
Start -> Run -> devmgmt.msc -> Device -> Details -> Hardware Ids
Each device has a "Vendor ID" and a "Device ID"
For example:
PCI\VEN_8086&DEV_15A0&CC_0200
You can "google" for "PCI\VEN_8086&DEV_15A0" . Search results will tell you this is Intel NIC i218-LM .
Additionally you can find your motherboard using "speccy" (https://www.ccleaner.com/speccy/download/standard) or "cpuz" (https://www.cpuid.com/downloads/cpu-z/)
Unfortunately this is part of the enthusiast experience where you do need to acquire basic IT skills to identify hardware if you do not know what it is exactly.
Good luck.
