Completed GUREN KNIGHTMARE HAF X - first watercooling build
Very nice looking set up. What are your temperatures like?
thank you :biggrin:
cpu 30° C in idle 50-55° C full
gpu1-gpu2 29-27° C idle 39-37° C full
nice build but the rez pics are showing bubbles in rez
these bubbles still present today ? and video shows something and the rez tub not to clearly for the reflections. is it clear or camera glare
the bubbles are gone, i've take the photos when i've just finish to fill the loop, so there were some bubbles and air in.
for the video i think it's camera glare
Very nice build you got there. I'm not a big fan of external radiator setups either, but you sure pulled it off. :thumb:
Your video is very static in that it's just one plain continuous shot. But at least you picked good tunes. You must see In Flames play live if you haven't already :punk:
wow that's a lot of rad capacity! does the extra 240 on top make much of a difference to your temps? i imagine the 360 on the inside and the rear external rad would be enough :\
nevertheless, very sexy rig, mate! :D
thank you guys! :)
yes the additional radiator help to control the water temp. under full load.
Meanwhile i've made some minor modification :biggrin: :
- switched from the RX240 to te RX480 on the top of the case
- added some Koolance VL3N quick disconnects on the external radiators, they are now full modular
- replaced the fittings under the GPUs and the ball valve with a Bitspower one.
- now i'm using Mayhems Pastel fluid.
i've also replaced my old power supply (noisy under load, tagan bz900) with a Seasonic 1000 Platinum
some photos :clap:
