Windows Server 2012 and Email
Tech686239
Nova Scotia
Hello Peoples,
Here is what i would like to do. I Have 4 emails, 2 eastlink and 2 gmail. What i would like to do is have all 4 go download from there servers to my windows server. Than beable to have clients on say my macbook or imac or gaming PC and see my email from my server on those clients.
Is this possible?
Thanks
Tech
Why do you need Server 2012 in this?
You should be able to setup all your email to forward to your "primary" email account.
I think you are talking about an exchange environment? based on what you are saying. If this is a single user case scenario outside doing it for kicks don't bother. Just forward emails as stated above, if you are doing it for kicks and want to know how to do it then yes you can do this. You need exchange and the pop collector.
Understanding the Microsoft Connector for POP3 Mailboxes
I understand what you are saying. I guess what i was thinking was that i could check my email on any one of my computers. I was worried about sync issue. So lets say i setup thunderbird on my macbook, it downloads the messages thats fine. Tomorrow i go and check my email on my imac with apple mail. If i have thunderbird not to delete the messages off the gmail server than i am fine but if i do i won't see all my messages. What i was thinking is if i had all my message download to my already setup windows server 2012 and then beable to check them on each of my computers from that it would be easier to manage. If it a bit problem its ok i can deal with it.
Thanks for the help
Tech
In Gmail, if you go to Settings > Forwarding and POP/IMAP, you can set it to forward all emails to a specific address.
Not sure what platform Eastlink uses for their email, but if you sign into their webmail, you may find a similar setting as well.
OMG.. you sir are my hero. Eastlink has something like this as well.
I have done this yet. Just have a couple of more quick questions.
When i look at the email will it tell me somewhere what email account it came from?
Let say i have the account that all my emails are forwarded to on different computer. Let say i check it on one computer and it deletes the email off the server. If i go and check my email on another computer will i still get that email?
Yes, by looking at the TO: address
using IMAP all the client computers will sync with the email server... if you delete a message that message will show as deleted for all clients. If you read a new message that message will show as read for all the clients.
And another tidbit, if you use Gmail as your primary, on the Accounts tab in the Settings, you can also send email to appear as though it's coming from whatever other addresses you have. Then you just pick which one to send it as while you are composing/replying to an email.
Also, alternative to forwarding (though it seems Eastlink supports it) would of been to setup POP3 in the Accounts tab. I suppose you could still use that too if you don't want any email copies left on Eastlink and want everything in Gmail.
It sounds like you are using "fat clients" though, so not sure how beneficial any of this is to you really. You should just be able to setup all 4 accounts in your client. Only benefit to what you are doing now is if you plan to access all your email via web-mail only.
