So the next big experiment for this build is to try out liquid metal (as opposed to regular thermal paste). After watching a lot of videos (and also noting in the Optimus docs for this block they also mention liquid metal being the best, here is where I got to...
(notice the super clean pre-cut thermal pads provided by Optimus!!!) - Anyway, cleaned and polished the chip, spread some over-priced nail-polish (but hey, lets support these small manufactures) over the active components, and cut out a small little foam barrier just as a last line of defense in-case anythign goes sideways (literally and figuratively) with the liquid metal.
Here you can see my cheesy attempt to try and map out how much of the block will be touching the chip, meaning I need to also cover that with a bit of liquid metal. (placed a small drop of the "nail polish" on the foam, then put the block on so it would mirror on the other side)
