Work in progress New Build - "Luvafair"
For a few other random pics - here is me trying to make a clean run of holes to allow for the 140mm rads vs the 120mm that it is designed for - good news is it turned out pretty good (even though they were a bit crooked)
Man I love painters tape..
And it is a tight squeeze but they fit
And now for a little bit of rad cleaning...
Definitely shook loose a few bits...For fun on this build I also decided I would use EK's system prep and wash out the entire loop, but either way, always start with the rad flush.
I love (and hate from a waste perspective) that the M2 mounting screws come in their own individual bags...I have a feeling if I ordered one on Amazon that tiny bag would come in a 1' square box..
And all in all, those are some nice looking drives. My current rig only has 3TB (and am probably only using half), decided on 2 x 2TB for this build..
One of the other interesting things that drew me to this case was the integrated power board (I f'n hate and suck at cable mgmt) - So you have short jumpers from your PSU to the power board here:
And then another set of short jumpers from the outputs of the power board that are conveniently located close to where they need to connect on the mobo... Definitely quick, easy and clean!
And then lastly, the case is theoretically designed to reduce the amount of tubes needed - I managed to reduce it even further by flipping the top rad on its end - usually it goes mobo block out, top rad in, top rad out to case - instead I went mobo out to case, and then with a few extra fittings, managed to make the connections between the two rads and the case. Will send full pictures later when the glass versions of the tubes arrive, but for now, this is all I need:
So this is where I stand right now - rads are in, CPU and M2s are installed so MOBO is ready to go. Just need to wait for the glass tubes to come in and I can connect up the loop and start running a final clean. In the mean time, started testing out some of the connections, see how the integrated lighting works...I have also not installed the last 2 fans as it will be easier to get the tubes in first, then add the last 2 fans (also, I need to order the last 2 fans as for my first order, they only had 4 in stock)
Meanwhile, also still struggling with the name for this rig...Also bummed that in order for the fans to blow out the top, they need to be "upside down" with regards to the "be quiet" logo :p
Well shoot @Bond007 I didn't even think about that - doing a quick google search, it is listed as being non-conductive (or for the most cases, non conductive?). From the "expanding" perspective, before I used it I confirmed that with the IHS on the chip, there was still a gap between it and the PCB, so I could confirm that when I first applied it and held down the IHS, it should've made tight contact.
Ultimately though, I only used a small bit of the glue (just a dab in each corner) - you really only need it (well technically you don't need it) to help manage the process of getting the chip into the socket, and then the contact frame on. From there its the contact frame that actually holds the lid in place, and firmly presses down on all sides of the IHS so I think I should be safe there.
And while this is by no means based on anything scientific - I have been power up the rig for very short periods of time (just testing out the wiring), and every time I watch the CPU reported temperature. Considering that it always starts at 35C, then continues to rise (I turn it off by the time it hits 39) - I am not sure if that's a good sign, bad sign, or just not a sign at all, and that really, I need to wait until I can let it run and stabilize in the loop with the coolant going. I just need to be patient.
If its booting find and temps don't jump quick, then I would assume a non-issue. Only reason I mentioned it is that there are many types of gorilla brand glue...some of them expand a lot.
