hey all
The pc is for virtualisation (windows 7 with vmware workstation, and dual boot with ubuntu and KVM)
i will use thi pc as my main pc also, soo web browsing, 1080p movie and some light gaming (mostly games in the last year, and starcraft 2
+/- 1000
ncix, i mostly pricematch to get all my piece there and make them build the pc (i hate building pc)
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
not really a fanboy but never use amd, but if they offer something good im open
i have monitor keyboard and mouse
default speed i never overclock
as soon as possible, but for the moment my notebook hold, soo I can wait
9. What resolution do you use?
1680 x 1050 using clone to 2 monitor (monitor and tv)
I want usb3, sata3 if possible, but i wont use it now.
another note I want my pc, if possible, to use less energy, more quiet and heat, as i will leave it on 24/7
i had 1 build in mind,
and intel P55
here:
intel xeon x3440
http://ncix.com/products/?sku=44109&vpn=BX80605X3440&manufacture=Intel
motherboard:
http://ncix.com/products/index.php?sku=46488&vpn=GA-P55A-UD4P&manufacture=Gigabyte
powersupply:
around 600-700W i presume
memory:
4gb of ddr3 memory (2 stick)
case:
coolermaster haf 922
dvd:
dvd writer
hard drive:
2 x WD black 640gb for RAID 0 (wanted samsung f3 500gb but ncix does not have them
graphic card
xfx ati hd5770
if i pricematch i could get this build for around 1000$
on the other end i could go with amd for around the same price, and maybe get a better motherboard chipset (more pci express lane, better for crossfire and usb3, even if i dont think i will use crossfire, but its always nice to have the option)
how does the amd processor compete in virtualisation against the intel. Particully the intel xeon x3440 got vt-x and vt-d technology, i dont know what is the equivalent for amd.
another option might be to wait for amd phenom x6, dont know how they would compete against the intel 4 core + HT
I'm open to suggestion on the amd side
thank you
+/- 1000
and intel P55
here:
intel xeon x3440
motherboard:
powersupply:
memory:
case:
dvd:
dvd writer
hard drive:
graphic card
xfx ati hd5770
thank you
