AMD Radeon HD 6990 4GB Review
Status
Not open for further replies.
BattleField: Bad Company 2 (DX11)
To benchmark BF: BC2 we used a five minute stretch of gameplay starting from the second checkpoint (after the helicopter takes off) of the second single player mission up until your battle with the tank commences. Framerates are recorded with FRAPS.
1920 x 1200
2560 x 1600
DiRT 2 (DX11)
DiRT 2 (DX11)
Being one of the newest games on the market, DiRT 2 cuts an imposing figure in terms of image quality and effects fidelity. We find that to benchmark this game the in-game tool is by far the best option. However, due to small variances from one race to another, three benchmark runs are done instead of the normal two. It should also be mentioned that the demo version of the game was NOT used since after careful testing, the performance of the demo is not representative of the final product. DX11 was forced through the game’s config file. In addition, you will see that these scores do not line up with our older benchmarks at all. This is due to the fact that a patch was recently rolled out for the game which included performance optimizations in addition to new graphics options.
1920 x 1200
2560 x 1600
F1 2010 (DX11)
F1 2010 (DX11)
1920 x 1200
2560 x 1600
Just Cause 2 (DX10)
Just Cause 2 (DX10)
Just Cause 2 has quickly become known as one of the best-looking games on the market and while it doesn’t include DX11 support, it uses the full stable of DX10 features to deliver a truly awe-inspiring visual experience. For this benchmark we used the car chase scene directly following the Casino Assault level. This scene includes perfectly scripted events, some of the most GPU-strenuous effects and lasts a little less than four minutes. We chose to not use the in-game benchmarking tool due to its inaccuracy when it comes to depicting actual gameplay performance.
1920 x 1200
2560 x 1600
Lost Planet 2 (DX11)
Lost Planet is a game that was originally released on consoles but in its port over to the PC, it gained some highly impressive DX11 features. For this benchmark, we forgo the two built-in tools and instead use a 2 minute gameplay sequence from the second level in the first chapter. The reason we use this level is because it makes use of three elements that are seen throughout the game world: jungles, water and open terrain.
1920 x 1200
2560 x 1600
Metro 2033 (DX11)
Metro 2033 (DX11)
There has been a lot of buzz about Metro 2033 which has mostly centered on its amazing graphics coupled with absolutely brutal framerates on even the best GPUs on the market. For this test we use a walkthrough and combat scene from The Bridge level which starts at the beginning of the level and lasts for about 3 minutes of walking, running and combat. Famerates are measured with FRAPS and Advanced PhysX is turned off.
1920 x 1200
2560 x 1600
Unigine: Heaven v2.0 (DX11)
Unigine’s Heaven benchmark is currently the de-facto standard when it comes to simple, straightforward DX11 performance estimates. While it is considered a synthetic benchmark by many, it is important to remember that no less than four games based on this engine will be released within the next year or so. In this test we will be using a standard benchmark run with and without tessellation enabled at three resolutions,
1920 x 1200
2560 x 1600
8x MSAA Testing
8x MSAA Testing
In this section we take a number of games we have tested previously in this review and bring things to the next level by pushing the in-game MSAA up to 8x. All other methodologies remain the same.
Note that 8x MSAA is enabled via the game’s config file for the NVIDIA cards since it is not a selectable option within the game menu
Dirt 2 (DX11)
F1 2010 (DX11)
Just Cause 2 (DX10)
Multi Monitor Gaming Performance
Both NVIDIA and AMD now have multi monitor output options for some truly immersive gaming. However, spanning a game across three or more monitors demands a serious amount of resources which makes this a perfect test for ultra high end solutions.
In this section, we will be testing multi card setups across three 1080P monitors with and without AA enabled. While all solutions have the ability to implement bezel correction, we leave this feature disabled in order to ensure compatibility. The benchmarks run remain the same as in normal testing scenarios.
Aliens versus Predator (DX11)
Dirt 2 (DX11)
Multi Monitor Gaming Performance pg.2
F1 2010 (DX11)
Just Cause 2 (DX10)
Metro 2033 (DX11)
Status
