Arcade !
2 months since last reply, but this build looks awesome, is it finished or still in the process? :bleh:
not to steal Brain's thunder, but the arcade is folding for the Chimp Challenge right now
Yea it's busy folding right now.
I actually started the primer coats on the sides yesterday....blocking out the primer will take some time tho....
I am getting closer.I'll be hunting down some black carriage bolts to replace the old ones this week probably.
:thumb:
Ok....
I'm finishing this sucker up.
interior primer coats...
The white primer bits need to get blocked out and reprimer'd but I'm almost onto the outsides....
Last major work ; rebuild the base :
The totally abused plywood base will be replaced with oak.
:thumb:
Oh yeah! I remember this, cool, glad you are able to finish this up. :biggrin:
Oak base, going to look great in the play-room :thumb:
