Conclusion
Conclusion
The ASRock Fatal1ty Z270 Gaming K6 is a solid motherboard that essentially performs as advertised. There are no noteworthy design or layout issues with the board, aside from the fact that the primary CPU fan header is a little too close to the MOSFET heatsink. However, that slight niggle stood out just because we’re constantly swapping fans, while most users plug them in once and that’s it until they upgrade years later. Other than that, the layout is downright great. Specifically, the excellent PCI-E configuration that allows for two dual-slot graphics cards and two open PCI-E x1 slots, or even two triple-slot graphics cards and one open PCI-E x1 slot. This flexible layout isn't really a new development, nor is it exclusive to this model, but we are just glad that manufacturers have widely adopted it for most of their full-size ATX LGA1151 motherboards. Speaking of multiple graphics cards, we were pleasantly surprised to see that ASRock have bundled a SLI HB Bridge to ensure optimal performance when running two GeForce GTX 1070's or 1080's in SLI. This high bandwidth SLI bridge usually retails for $30 USD, so it is a very nice addition.
We also love the fact that they omitted any SATA Express or U.2 ports. The simple fact of the matter is that there just is not enough support for those two interfaces among storage device manufacturers. Therefore, why waste valuable I/O connectivity when you can add another couple of SATA 6Gb/s ports that will be useful to a much larger user base.
If you skipped the introduction, here is another rundown of this models’s specs list: a 12-phase CPU power design, high-quality 12K Japanese capacitors, three steel-reinforced physical PCI-E 3.0 x16 slots with support for 2-way SLI or 3-way CrossFireX, three PCI-E 3.0 x1 slots which are open-ended to accept longer expansion cards, eight SATA 6Gb/s ports, one M.2 Key E slot, and two full-speed PCI-E 3.0 x4 M.2 slots that support Intel’s upcoming Optane technology. There are also two high-speed USB 3.1 ports, one Type-A and one Type-C, four USB 3.0 ports, two USB 3.0 headers, three USB 2.0 headers, and an RGB LED header. Rounding things out are two Intel-powered gigabit LAN ports, two physical BIOS chips, a debug LED display, and DVI-D/HDMI 1.4/VGA video outputs.
For starters, we would have gladly sacrificed the VGA output for a DisplayPort. Having said that, since this is a gaming-oriented motherboard it would be a damn shame if there wasn’t a proper graphics card installed. Moving on, the rear I/O panel is a little sparse with only five USB Type-A ports, but it’s not the end of the world when you consider that this motherboard has five internal headers that can supply an additional 10 USB ports. When it comes to networking, the two gigabit LAN ports are not something that we usually see at this price point, and we like the fact that ASRock used both one modern ethernet controller and one older but widely supported controller. We also love the addition of the M.2 Key E slot. While we understand that excluding onboard Wi-Fi was necessary in order meet a certain price target, that slot makes super easy for a user to install one of the numerous M.2 Wi-Fi cards available. The antenna cutouts on the rear I/O panel also help make sure that adding wireless connectivity is a painless procedure.
When it came time to test the Creative Sound Blaster Cinema 3 onboard audio, we were excited because this was our first time with the new Realtek ALC1220 codec. We expect to see this codec on all but the most budget-constrained Intel 200-series motherboards. While the audio numbers were generally good to very good, they weren’t substantially different than the average ALC1150-based onboard audio implementation. Considering this model’s price point, we would have liked to see an EMI cover on the codec, as that might help the numbers a bit. Overall though, when actually listening to the audio output with a mix of headphones and speakers, we had zero complaints.
The AURA RGB LED lighting feature is a timely addition, and it both looks good and works very well indeed. We like the fact that ASRock used really beefy RGB LEDs – much larger than we have seen before – that can really put out a ton of light. Both the software utility and the UEFI sub-menu gave us ample control over the lighting effects and colours. We do think that some LEDs should have been added somewhere near the memory slots in order to keep up with what the competition is doing, but maybe we will see that in some higher-end models. We also can’t help but have mixed feelings about the fact that ASRock are really encroaching on ASUS’s AURA RGB nomenclature with the name that they chose for their lighting feature.
When it came time to overclock, the Fatal1ty Z270 Gaming K6 proved itself to be very capable. The three automatic overclocking features worked very well, achieving results ranging from 4.5GHz to all the way up to 5.0GHz. Since this was our first time overclocking the new Core i7-7700K, we were very surprised to see that 5.0 result, especially since it was all done auto-magically. However, that most aggresive of the five Optimized CPU OC options did set an elevated 1.45-1.46Vcore. In our opinion, that is too high for a day-to-day system, even if it is stable – which it was – and even if you can keep the temperatures under control. With that in mind, we now knew what the limit was and started working on our manual overclock. Priority number one was to figure how low we could drop the core voltage while still maintaining that very high clock speed. In the end, we settled 1.36V, which seems pretty good to us for 5.0GHz. The motherboard didn’t hiccup once during our manual overclocking efforts, and we were also able to increase the cache frequency to 4.6Ghz. Regrettably, things weren’t so perfect on the memory front. We were able to run our memory kits at up to DDR4-3733, but we did not have success going higher, even when simply trying to apply our G.Skill Trident Z’s DDR4-3866 XMP profile. This is not unusual for a new platform, and there might be a new BIOS that improves the situation, but we do have to point out that we experienced a similar situation on the ASRock Z170 Extreme4+.
The other area where we consistently ran into a few difficulties was the software package. While the primary apps that we would actually use on a regular basis all worked well, a few of the other utilities either wouldn’t install or did not function properly once installed. Now we are dealing with a pre-release motherboard, and it’s not absurd that the software is not perfectly tailored to this new CPU/chipset combo, but just be advised that it is currently a work in progress.
In the end, the Fatal1ty Z270 Gaming K6’s launch price of $180 USD will undoubtedly place it in a very competitive arena. We don’t actually know what the field is going to look like yet, but that price point is a high volume one that all manufacturers fiercely compete for. Based on what we have seen today with this model, ASRock have a compelling product that should be on everyone’s radar. The design and hardware choices that they made are generally excellent, and if they can iron out the few software abnormalities and improve memory overclocking a tiny bit, the Fatal1ty Z270 Gaming K6 will be hard to beat.
