Okay, so now that I sorted out 1/2" (from my old build) does not work with 12mm fittings (thanks to science and math) I bought some 12mm tubing from Daz (along with more fittings) to start building.
I also bought some Bitspower PETG and Crystal 12mm tubing, and what I wanted to know from folks is are your connections tight as all crazy? I noticed when I was working with 1/2 fittings the tubing slipped in a lot easier. On the 12mm ones I have to apply a lot of pressure. I noticed that the one o-ring (for the outer piece) has to stretch a bit to get on the tube, so I guess that is what I am forcing for the inner o-ring?
I also tried lubing it up a bit, just to see if that helped.
Anyway just wanted to see if I was the only one with this issue?
B
B
