DDR5 RAM - Compatibility and RAM Training
Is it the board doing some sort of auto-overclock then? Is there any way to enable it outside of the "Ai Overlock Tuner" option?
I enable it on the home page. I've checked through BIOS settings to look for anything to change expo settings, but don't see it.
I've had other ram kits through this debacle that register correctly with expo.
All the above out of the way, I was at MemEx and they scrounged up an open box kit that should work for me. ($150 cheaper than the dominator for the same specs.) I'll be swapping the ram kits and returning the insanely overpriced dominator ram to Amazon. Here's hoping everything works moving forward.
For the best anyway, as the RAM was REALLY pushing size limits. With the radiator as far over as it would go, the LED caps on the heatspreaders were still touching the side of the fans...
