Hi fellows,
I just bought the Edifier S360DB speakers. I am using Windows 11. I tried to hookup the optical cable to my PC and the speakers and I do not get any sound from the speakers. Both the subwoofer and side speakers are plugged-in and turned on. I set the side speaker to OPT, meaning optical cable.
No luck.
I followed the manual, but I cannot get it to work!
Can you fellows help me to fix this issue?
Thank you in advance,
CG
No luck.
CG
